engine too close to axle,is it possible?
Old Jul 29, 2018 | 06:21 PM
int3414's Avatar
int3414 will become famous soon enough
Default engine too close to axle,is it possible?
2000 blazer,makes a grind/squeaking noise if you gas it hard from almost being stopped,oil pan looks mighty close to the top of diff.,the mounts for axle look like they could be worn in frame,,does any of this make sense??...maybe i shouldn't worry and just let it ride??,,,TIA
Old Jul 29, 2018 | 06:52 PM
Pics? The carrier is mounted solid in place under the engine. They're close, but should never come close enough to contact, even if a motor mount (or both) completely come apart. I think you may have a different issue.
Old Jul 30, 2018 | 04:04 AM
int3414's Avatar
the noise is bugging me,i compared the oil pan to axle clearance to my 2000 jimmy,it too is a bucket of rust...just finished the front brake and rear lines and calipers,,,considering upper a-frames...its ugly....baffled bye that noise?
bountyhunter77
Jan 6, 2013 03:49 PM
BLAZER97LS
Apr 29, 2012 03:07 AM
marlboro124
20
Oct 6, 2011 11:55 AM
Briz600
Aug 23, 2009 08:05 PM
tawd77
Feb 14, 2008 03:29 PM
