Ac blower not turning on sometimes
Old Jun 3, 2015 | 05:57 PM
Andrewwood's Avatar
Andrewwood is on a distinguished road
Thanks for the help. I took it to a local shop and the found at first the plug had only 8volts of power they wiggled and played with it and then it got 12v and my blower kicked on. They diagnose it as possibly a binding blower motor that damaged the module. Reccomending me changing the motor and module. I told them I plan on doing it my self so I don't think they are lying. Does this sound probable?
Old Jun 3, 2015 | 07:33 PM
Very possible. However, the module changes the speed of the blower by increasing or decreasing the voltage to it via PWM. Might want to unplug the connector at the blower motor, and apply battery voltage and ground directly to the motor terminals. It should come on and operate at full speed. Checking amperage draw would tell if the motor is faulty, (drawing too much amperage could cause the module to fail).
Old Apr 3, 2017 | 04:09 PM
Andrew Wood's Avatar
Andrew Wood is on a distinguished road
im still having issues with this blazer, I've replaced the blower control module and the blower motor its self. After hooking the multi meter to the plug the goes into the blower control module I did receive increasing and decreasing voltage from the signal wire when adjusting the air speed control on the dash. But when I connected the meter To the wires leaving the blower CM I could only get around 3.4 volts to the blower motor. This is a brand new AC Delco Blower CM I bought today. Is it likely it's bad?
Old Apr 3, 2017 | 05:00 PM
Also I was wondering if I could Hotwire the blower? If so what do I do? I'm asking Because it has auto climate control
Old Apr 6, 2017 | 06:36 PM
im hoping you still use this site Captain Hook. Seems as though it's hard to get a decent reply from some one experienced like you..
comandoed
Nov 8, 2013 11:00 AM
Eric S
Mar 18, 2012 07:12 AM
novaman66
Mar 21, 2011 08:19 PM
Dirsuper
Jan 18, 2011 12:07 PM
byrm31
Dec 7, 2010 08:29 PM
