AC circulation problem
Old Apr 23, 2009 | 07:05 PM
jbgpr's Avatar
jbgpr is an unknown quantity at this point
Default AC circulation problem
I have 1999 blazer and the ac blows ok. When i press the recirculation button nothing happens. It use to work just fine you could tell when it changes over, now nothing.
I checked all the fuses and they are fine. Just don't get it. Any ideas?
Old Apr 23, 2009 | 07:16 PM
The recirc door is vacuum actuated. You can see the actuator by dropping the glove box down out of the way. Open you glovebox and empty its contents. Look up in the left corner of the glove box for the catch. Pull back on the catch and rotate the glovebox door down and out of the way. The large plastic opening with a vacuum actuator in the middle of it is the recirculation door/grill. When you press the recirc button, you should have vacuum to this actuator. If you do not, then the problem could be in your control module. If you do, then the actuator is bad.
jbeganny
Dec 31, 2011 09:10 PM
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
