AC compressor HELP
I have a 1999 blazer with the v6 in it. My ac compressor runs great sometimes and sometimes it just shuts down for no reason at all, I am full of freon and all relays and fuses are good. When the ac compressor stops working I have voltage at the fuse box on the side of the dash and no voltage to the relay and fuse under the hood. I am stumped I have tried to run wire down and I can not find any loose or bad connections, PLEASE HELP, thank you.
![Icon Shrug](https://blazerforum.com/forum/images/smilies/icon_shrug.gif)
when the clutch kicks out or isnt engaged when its supposed to be on, pop the hood and take a piece of 1x2 and a hammer and tap the clutch face plate and see if it comes on, if it does then the air gap on the clutch is out too far
I have tried tapping on the front of the clutch and all over the compressor and even run down all wires that have to do with the ac unit, I am just not getting any voltage at the relay and fuse thats under the hood. Do you think it might be the ECM ??? Im stumped. THANKS for your help
I don't know what to tell you if you aren't getting voltage to the relay or the compressor the only thing that might be causing such a thing might be the selector switch
Could you tell me how I would go about testing the selector switch ??? Thanks
Ok here is the deal, I can let the blazer set overnight and everything works fine the next morning but once I drive it for 10 - 15 minutes the ac compressor looses power and the fuse and the relay under the hood has no voltage. I am stumped.
Hey Red...I have a similar problem with my '98. I don't want to hijack your thread so I started my own, plus I have pictures in mine :-)
Maybe together we can figure this problem out.
Will
Will
gmcjimmy_94
12-30-2010 12:37 AM
04blazer81dobie
06-13-2010 06:16 PM
muleman
05-26-2008 01:11 PM
2000, 2009, 95, ac, air, blazer, chevy, compresser, compressor, compressorno, conditioner, gmc, jimmy, receiving, voltage
