Ac delco original part # 25176789 Or superceeded part # 19177220 updated part?
Old Nov 17, 2011 | 06:25 PM
pettyfog's Avatar
Originally Posted by Captain Hook
When you install the new pigtail, solder it to the vehicle harness using rosin core solder and use heat shrink tubing for insulation. DO NOT use the cheezy crimp connectors that come with the new pump. Crimp connectors should never be used on a vehicle.
Here's the lock ring, you might not need it but it's best to have it handy in case you do: Buy Airtex Fuel Pump Lock Ring LR3002 at Advance Auto Parts_____
As mentioned, lube the O ring before installing the pump into the tank to keep it from rolling. If it doesn't seal properly you'll get EVAP DTC's.
AMEN on the crimps!
If you dont feel you can comfortably solder the connections, then use silicon lube filled twist connectors, avail at any Lowes or home depot. Dont forget to stagger the splices so they arent all in one big clump
I have a writeup on my own fuel pump saga, here.
Including what to look out for and how to fix what you screw up
https://blazerforum.com/forum/2nd-ge...s-fixed-63397/
My local dealer sold me the proper ring for plastic tank for $26
NO local stores NAPA, Adv, AZ, OReilly's had em. NAPA did at whse for next day.
Old Nov 17, 2011 | 06:27 PM
Originally Posted by Mike98Blazer
If he's got the plastic fuel tank that may not be the lock ring he needs.
Good call, Mike! I missed the plastic tank.
StarBlazing
Sep 27, 2014 11:27 AM
Dadatone
Aug 24, 2012 09:10 PM
pettyfog
Mar 18, 2012 08:49 PM
Tortex53
Mar 12, 2011 12:51 PM
2000Jimmy
Jan 29, 2011 06:40 PM
