AC Guidance
Old May 28, 2014 | 09:17 AM
Jesster's Avatar
Jesster is on a distinguished road
Default AC Guidance
I have a 1996 Blazer LT 4dr 4wd 4.3L engine.
Last Labor Day weekend, I noticed a light oil spray residue around the hose connector (aluminum 2-hose) on the top of the AC compressor. I pulled the compressor clutch wire so as to not cycle it.
Fast forward to now. I have replaced the O-rings on the connector and have borrowed a nice 2.5 cfm AC vacuum to clean the system. I will replace the dryer; but I have a question before going to get parts. Do I need to replace the orifice tube or will the AC vacuum remove whatever is there from it? The guy I borrowed the vacuum from says he hasn't ever replaced an orifice tube, but that the dryers do get clogged and need to be replaced.
Old May 28, 2014 | 12:28 PM
Jesster's Avatar
Default Orifice Tube Orientation
I decided to replace the orifice tube with a variable tube. The AC on my blazer never did work very well (bought used with 50,000mi) and I was going to check the orientation of the tube when I replace it as I don't know who has worked on the AC before. After researching, it seems as though the short-end of the tube gets put into the evaporator first and the long end needs to be towards the condenser side. Any input would be helpful.
Old May 28, 2014 | 09:05 PM
The short end goes into the evaporator inlet tube first. Push it in until it stops. Then oil the O ring and install the high pressure liquid line from the condenser.
hargrovewill
Apr 21, 2014 06:26 PM
jatkins3983
Headers, Intake, & Exhaust
Oct 24, 2013 08:23 AM
OffRoadNLovinIt
Jul 8, 2013 12:48 AM
metalmilitiacdr
May 2, 2011 07:29 PM
Vicer_Exciser
Nov 28, 2010 09:54 PM
