AC leak
Old Jun 17, 2012 | 05:03 PM
Fourstar200's Avatar
Fourstar200 is on a distinguished road
Default AC leak
Hey guys I had a question about my air conditioning. I've had problems with it since I got my blazer. All of the air conditioning components have replaced. It started when it wouldn't stay charged. I figured out that the hose assembly wasn't tightened all the way to the compressor. so I tightened it and it still won't stay charged. I can't see any leaks but my thought is that the leak caused the system to loose its vacuum. Could this cause it to not stay charged or is there a leak somewhere that I just haven't noticed? Any help is appreciated.
Old Jun 17, 2012 | 07:36 PM
50lb_cat's Avatar
I would either put some r134a that has dye in it or take it to a shop that has an electronic sniffer. How long does it take to loose charge?
Old Jun 17, 2012 | 08:41 PM
It usually takes about 5-6 days to fully loose the charge
Old Jun 17, 2012 | 09:58 PM
50lb_cat's Avatar
That is a pretty bad leak. You should be able to find it using dye.
Old Jun 17, 2012 | 11:52 PM
Yeah I'll have to try that. Thank you for the quick response. Much appreciated
Old Jun 18, 2012 | 12:03 AM
TAS's Avatar
TAS
TAS is on a distinguished road
Default A/C help!
Opps Sorry - Wrong thread.. See my new thread in the main forum
Old Jun 18, 2012 | 12:16 AM
4x4blazerguy's Avatar
Smile
You need to evacuate the system & recharge. How do you know you are not overcharging the system which will give you limited cold. R134A & any of the synthetic freons act much different than R12. You could get away with a little over charge but not true with the synthetic freons. To work correct they need to be charged exactly to what is called for.
ComputerNerdBD
Aug 9, 2011 08:04 AM
BubbaBrooks
May 18, 2011 08:38 PM
abadinalbany
Jun 1, 2009 08:27 PM
TAZ454
Jan 28, 2008 10:11 AM
