ac not working
97 blazer 4.3 auto
last summer ac worked fine. every year or so i have to add some feron, less than a can. this year no work. using my can guage it showed over charge. my friend who is an old school mechanic put his good set on it and said it was low charge, he added about 20 ozs. low pressure is 50 and hi pressure is 150 psi. air temp was 35 F using IR temp probe. an hour later I took it for a ride and no a/c ir probe was ambient temp. put gauges on and and pressure were still 50 /150. he thought there may be an internal blockage (orfice tube). before we added freon compressor was cycling, after adding it stayed on. it is still on and not cycling now. any thoughts????
thanks
bernie
thanks
bernie
Its inside of the inlet tube (smaller diameter tube) going into the evaporator. Keep in mind if you open the system to replace it you need to get it evacuated first! And you should also replace the accumulator while you are at it. Then refill your system.
mjw1991
Feb 24, 2013 10:18 PM
bootlegger
Dec 14, 2010 05:18 PM
218persuader
Aug 20, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
