AC recharge 97 Blazer
Old May 18, 2009 | 09:56 PM
brf2's Avatar
brf2 is on a distinguished road
Default AC recharge 97 Blazer
Just got a 97 Blazer and need to recharge the AC. Have the Universal recharge hose but it doesn't fit or I'm not finding the right fitting or do I need a different fitting? Does it take 134? any help appreciated
Old May 18, 2009 | 10:37 PM
You are probably trying to put the hose onto the high pressure fitting. The low pressure fitting is on the silver canister closer to the firewall.
Check out the Tech Article (DIY) section for more information.
Old May 18, 2009 | 10:38 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
A 97 does take r134a the fitting you want is the low pressure fitting which is welded onto the accumulator/drier which is a the aluminum can on the passenger side near the firewall. Doh you beat me by a few seconds.
Old May 19, 2009 | 07:23 PM
brf2's Avatar
Default Universal Air Conditioning Fitting
Thanks for the replies. I found the canister fitting but it is not the universal fitting that I have. Does it take a different fitting or am I in the wrong place. I talked to a friend that has a 2000 blazer and he can use the universal fitting and said it was on the canister. Thanks for the help.
Old May 19, 2009 | 07:56 PM
portcqb's Avatar
If it doesnt fit you must have an r12 hose with fitting or something. All r134a systems have the same low pressure port
carterx
26
May 25, 2014 12:00 AM
Jello0123
Jun 11, 2009 01:34 PM
abadinalbany
Jun 1, 2009 08:27 PM
blazerlt01
Jun 18, 2007 07:51 PM
hockeykid15
May 7, 2007 10:02 PM
