Accel or AC delco
Old Dec 19, 2012 | 08:15 PM
  #21
chris015's Avatar
word^
Old Dec 19, 2012 | 10:26 PM
  #22
armykyle1's Avatar
armykyle1 is on a distinguished road
Originally Posted by Captain Hook
Silver, copper, and gold, followed by aluminum are the best conductors of electricity. AC Delco caps use aluminum terminals. The problem with aluminum is that it oxidizes. A dab of silicone dielectric grease on each terminal, (inside and out) of the cap, slows the oxidation process. The insulation of the runners in the cap is an area that the aftermarket manufacturers fail miserably at, they can't seem to get it right. As a result, you end up with crossfire in the cap. Stick with AC Delco cap & rotor. Make sure that camshaft retard is within factory specs, that alone will increase cap & rotor longevity. AC Delco 41-993 plugs with a gap of .060" along with Autolite Professional Series wires. They're 1/3 the price of AC Delco wires and have better specs.
There's my
Thanks. That's cool, I picked up the autolite wires! I really appreciate the info. I don't mess with these old distributor ignition setups often. I'm more accustomed to coil on plug or coil pack setups ya know.
Old Jan 18, 2013 | 05:41 PM
  #23
bobydigital's Avatar
bobydigital is on a distinguished road
i wish i had read this earlier... i just installed a new accel cap and rotor this evening. hopefully it will last for a while. ( bosch premium wires and ngk plugs going in tomorow)
Old Jan 18, 2013 | 05:45 PM
  #24
Diaita's Avatar
i just pulled out a set of NGKs. they were in good shape after 9 years..
Old Jan 20, 2013 | 08:20 AM
  #25
thats good to hear. long life is a must as hard as they are to get to lol
Old Jan 20, 2013 | 09:25 AM
  #26
rexazz2's Avatar
I had a clear plastic HEI cap on one of my old V8's
It was cool to see running in the dark LOL
I would have thought the ignition rotor spun much faster at idle than it does BTW
I prefer delco plugs on GM ,NGK on imports , champion for dodge and Autolite on Ford
Because of the stated issues with 4.3's I would likely always use all delco stuff
Old Jan 20, 2013 | 12:44 PM
  #27
Originally Posted by rexazz2
I would have thought the ignition rotor spun much faster at idle than it does.
Rotor turns at half the speed of the crankshaft.
I prefer delco plugs on GM ,NGK on imports , champion for dodge and Autolite on Ford.
Stick with that and you can't go wrong.
Old Jan 20, 2013 | 05:21 PM
  #28
step66's Avatar
Happen to have a set of Bosch plugs in my unit with an Echlin cap&rotor-no problems,anyone that says that one has to have AC parts is wrong!
I have been running quality aftermarket products for 35 years in all my Chevys and never had a lick of problems! I have found that QUALITY replacement parts are far superior to Delco junk,especially in the small blocks!
Dadatone
Aug 24, 2012 09:10 PM
caddy500
Dec 3, 2008 07:27 PM
1987s10blazer
Oct 26, 2007 09:47 AM
tsuyoshi077
Oct 22, 2007 07:43 PM
xxx6thirty6
Sep 7, 2007 06:18 PM
