L35 surges at idle & on light accel.
Old Nov 17, 2008 | 09:00 PM
caddy500's Avatar
caddy500 is an unknown quantity at this point
Default L35 surges at idle & on light accel.
High I just put an L35 in my 1991 4door blazer. It seams to run ok other than a rolling idle sometimes and when accelerating. I did replace the regulator and put the correct fuel pump in when I did the swap. It doesnt seem to surge as much when it's cold.
Old Nov 18, 2008 | 08:15 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: L35 surges at idle & on light accel.
Did you check/clean the EGR valve before you dropped in the engine?
Old Nov 18, 2008 | 04:08 PM
Hanr3's Avatar
When cold the IAG controls idle, once it warms up the TPS controls idle. Verify they are both working properly.
Old Nov 18, 2008 | 06:42 PM
The IAC is in control of idle speed all of the time. The TPS is just a sensor and cannot physically move the throttle.
With a rolling idle, I would tend to agree with Leeann about the EGR.
Old Nov 18, 2008 | 10:37 PM
caddy500's Avatar
I have had a problem with carbon getting stuck in the pintle of the EGR. I just take it off push the pintle the get the carbon out. Then seems to be fine. Also I do not have any DTCs in the ECM
Old Nov 25, 2008 | 09:08 PM
caddy500's Avatar
I think I found the problem. The IAC valveseems to be acting slowly turning on and off.
Old Nov 29, 2008 | 09:25 PM
caddy500's Avatar
IT WAS THE HEATED O2 SENSOR!!! thanks for your help
Old Dec 3, 2008 | 07:27 PM
caddy500's Avatar
i was wrong, not the o2, not the iac.
emanshah
Sep 12, 2012 03:48 AM
Frog
Apr 30, 2012 11:16 AM
Bonzaibob
Apr 17, 2012 11:11 AM
Kenomee
14
Jan 29, 2011 12:01 AM
proper
Jan 13, 2010 06:49 PM
