acceleration problem
Old Aug 3, 2009 | 01:11 AM
mjfiedler's Avatar
mjfiedler is an unknown quantity at this point
Default acceleration problem
I have a 2000 Blazer, and have been having acceleration problems for several months. When I first start it up and press down on the gas it just chugs and doesn't want to go. After about 30 seconds or so acceleration returns and I don't have any problems. Also, if I start it and run it for about 30 seconds it will run fine.
I replaced the fuel filter awhile ago but that didn't help. The fuel pump went out about a month ago and when I got it replaced I hoped that it would fix the problem, but no luck. I put in some STP a few times, but that didn't help. I got some Sea Foam as well but that didn't work either.
Any ideas?
Old Aug 3, 2009 | 01:15 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
when was your last tune up? i hope you atleast changed the plugs after you did the seafoam, but if not i would suggest a full tune up.
Old Aug 3, 2009 | 01:28 AM
mjfiedler's Avatar
I just put in the seafoam last week and the gas tank is nearing empty without improvement. Do you think changing the plugs will fix the problem? Whatever the problem is, I can't figure out why letting the engine run for a short while would make a difference.
Old Aug 3, 2009 | 01:33 AM
mikeinwi's Avatar
doing a full tune up sure wont hurt things
Old Aug 7, 2009 | 02:19 PM
mjfiedler's Avatar
Ok, got a full tune up, replaced plugs, replaced fuel filter, etc. No improvement whatsoever. Any other thoughts or ideas?
tdbone1
Dec 20, 2012 09:40 AM
ototlewis
May 9, 2011 09:54 PM
ABN31B
25
Nov 19, 2009 08:47 PM
coltc
Feb 27, 2009 09:00 PM
SniperX13
May 1, 2006 02:11 AM
