Acceleration problems afrter warm up
I have an 1997 blazer with 202,000m. When it warms up it starts to misfire and will not accelerate. the more i drive the worse it gets. If i stop for a wile it gets better but then comes back. No check engine light. but if I hook the scanner and clear the computer it starts running good again. I hooked a scanner and read the out put of all the sensors and they look OK. ( all 4 O2= .650ish, MAF=.59, MAP=9.7) today I replace the plenum gaskets, MAP, air filter, pcv and some of the vacuum lines. No difference. I thought I had a bad tank of gas because it when away when i put some Mid grade in but the next tank of Mid grade it came back and wouldn't go away? HELP
Well I cleaned the maf again real good and it seems to have helped a lot, but its still dose it after it gets good and hot. But the strange thing is if i pull over and clear the computer it goes away. I was thinking it was a vacuum leak and the computer is adjusting for it till something goes out of range. Could it be the computer? I put plugs wires cap and rotor 40,000m ago and the might need replacing but it runs so good cool and when I reset the computer.
tdbone1
Dec 20, 2012 09:40 AM
andomwoodard1977
Sep 5, 2007 09:25 PM
