Adjusting Cam Retard
Old Dec 12, 2015 | 12:34 PM
LannyL81's Avatar
Default Adjusting Cam Retard
The TECH 2 tool shows cam retard to be at 2°; which way do I rotate the distributor, CW or CCW to adjust to zero?
Thanks
Old Dec 14, 2015 | 03:06 PM
HardKnock's Avatar
HardKnock is on a distinguished road
The distributors are none adjustable. Meaning that you can not adjust timing through moving the distributor.
Old Dec 14, 2015 | 06:29 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
There should be enough play to get 2 degrees worth of movement. Mine was -10 and I really want to say I ended up rotating mine counter clockwise to get to 0. I had to elongate the bolt hole in my distributor clamp though.
(And no, I didn't have the distributor off a tooth!! )
Old Dec 17, 2015 | 06:11 PM
LannyL81's Avatar
I will try CCW...once I figure-out how to get to the hold-down bolt. When I put the new distributor in I had the air plenum off so it was pretty easy to get to the hold-down bolt...now not so much.
So far have tried a universal and socket...but that did not work...hit bottom of distributor. No room to swing a wrench. May have to take a few things off to access it.
Old Dec 17, 2015 | 07:14 PM
HardKnock, Moving the distributor does not affect ignition timing on this engine. Moving the distributor adjusts camshaft retard, which actually aligns the camshaft position sensor with the camshaft, and the distributor cap to reduce or eliminate crossfire inside the cap. It is slightly adjustable from the factory, and if more adjustment is needed, the hold down bracket must be modified, or install a SBC, (small block Chevy) hold down bracket.
LannyL81, 1/4" drive, 10mm, 6 point swivel socket, on a 6" extension, gets right in there
Craftsman.com
Old Dec 17, 2015 | 08:20 PM
CWBDDSPC's Avatar
I had a -10 and went CCW. If you are at 2 go just a smidge CW...
Old Dec 20, 2015 | 01:11 PM
LannyL81's Avatar
Well...tried a 1/4" 12pt 10mm socket with universal joint and it still hit the bottom of the distributor preventing socket from seating onto the bolt head.
Ended-up using a 10mm 12pt closed or boxed end wrench with a large offset to lossen the clamp bolt.
Made a reference mark and then rotated the distributor body CW and retightened the clamp bolt. Will have to go see friend that has the TECH 2 and see how I did.
Thanks all.
Possum 6991
Jan 28, 2015 06:36 PM
MThompson
Mar 1, 2014 04:19 PM
Jesster
Feb 3, 2014 06:15 PM
phantom
Aug 14, 2007 07:38 AM
