After Heater Core swap....2001 Jimmy wont start
Old Sep 5, 2007 | 09:04 AM
redpeppers's Avatar
redpeppers is an unknown quantity at this point
Default After Heater Core swap....2001 Jimmy wont start
Like the topic says...i swapped the heater core out on my 2001 GMC jimmy and now it will not start.....just cranks......i am almost postive i hooked all harness' back up. I check voltage at the ignition harness and it is all good.....any have any suggestions?
Old Sep 5, 2007 | 12:03 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default RE: After Heater Core swap....2001 Jimmy wont start
Is the battery grounded properly?
Old Sep 5, 2007 | 05:56 PM
redpeppers's Avatar
It seems to be because the engine cranks just fine and all componants on the dash and radio are working fine also.
Old Sep 5, 2007 | 10:01 PM
redpeppers's Avatar
Update....there is not spark out of the dizzy so i am leaning towards something in the dash not hooked correctly
Old Sep 6, 2007 | 01:27 AM
Chevy Lover's Avatar
Keep us posted. Sure sounds like something didn't get a good connection.
Did you happen to disconnect and move the PCM out of the way?...........hmmm, maybe a poor connection there.
Old Sep 6, 2007 | 03:41 PM
redpeppers's Avatar
Yes I did move the PCM up and out of the way becuase i had to remove the inner fender which sets on that fender.
Old Sep 7, 2007 | 11:37 PM
redpeppers's Avatar
UPDATE: There is no output from the Coil. Does anyone know of a way to test the coil or know what voltage is suppose to be present on the wire harnessthat are going into the coil? Thanks
Old Sep 8, 2007 | 01:29 AM
[ol]Turn ON the ignition, with the engine OFF.
Measure the coil ignition1 voltage with a DMM connected to a ground. [/ol]
Does the voltage measure above the specified value?
10.0V
[ol]Probe the IC timing control circuit with a DMM set to the AC scale connected to a ground.
Crank the engine.
Observe the voltage while the engine is being cranked. [/ol]
Does the voltage measure within the specified values?
1.0-4.0V
Sorry I don't have time for more detail at the moment.
Do you have a manual of some sort?
Old Sep 8, 2007 | 10:31 PM
redpeppers's Avatar
Where will i find the IC timing control circuit
Old Sep 10, 2007 | 12:40 AM
redpeppers's Avatar
10.0V "
This does not have any voltage present..........and all fuses (that i can find) are good
