After Heater Core swap....2001 Jimmy wont start
Old Sep 10, 2007 | 01:00 AM
Chevy Lover's Avatar
Default RE: After Heater Core swap....2001 Jimmy wont start
Check for an open or shorted to ground ignition positive voltage circuit at terminal A of the ignition coil.
It sounds like either something didn't get connected. Did you check for bent pins in the connectors of the PCM or any other connectors that you may have removed?
Old Sep 10, 2007 | 01:56 AM
redpeppers's Avatar
redpeppers is an unknown quantity at this point
Sorry....there is voltage at the Pink wire at the coil.....there is also voltage at the Ignition Control module. There is a extra wire at the coil's harness that is white/black and it runs to the ICM....i am not sure how to test this wire ......any suggestions and also sorry about the last post that said i had no voltage at the coil i was using the DMM wrong (wrong setting :-)
Old Sep 11, 2007 | 01:07 PM
Maybe this will help
[IMG]local://upfiles/2910/97595F7588184FB6B1AE04184FA631B9.gif[/IMG]
sy24
Aug 10, 2011 10:52 PM
Denominator
Apr 24, 2010 05:17 PM
scrounger
Nov 11, 2009 10:35 AM
mudd4
Aug 23, 2008 08:46 PM
Chadoo951
25
Feb 10, 2008 11:26 AM
