aHHHHHHHHHHH HELP ME 98 BLAZER
try rolling the motor to TDC and then pull the distributor cap and make sure that you have the thing in there right. when at TDC the rotor should be pointing that the plug wire that goes to cylinder one. if it isnt, pull the distributor and re-align everything.
Is the starter turning it over? Air filter not clogged? Do you have proper fuel pressure(55+)? Do you have spark? Is it in the right order and at the right time? Evidence of fuel spraying? If all these can be answered yes then it should run
