Air Bag Light
Old Dec 2, 2009 | 01:34 PM
JSBlenz9498's Avatar
JSBlenz9498 is on a distinguished road
Default Air Bag Light
My air bag light comes on sparatically. I went to try to get it inspected today and of course it was on. The guy told me he wouldnt give me a sticker unless it was off so he just told me to make it disappear and he will pass me. Any suggestions to turning it off? Or pulling the bulb out of the dash?
Old Dec 2, 2009 | 01:51 PM
ABN31B's Avatar
Yank the fuse. problem solved! (ish....)
use this little gem FTW!
Old Dec 2, 2009 | 08:52 PM
will pulling the fuse turn the light out? Would pulling the bulb be easier?
Old Dec 2, 2009 | 08:59 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
You didn't say what you have, but newer models have LED lights in the cluster, you can't simply pull a bulb.
Old Dec 2, 2009 | 09:02 PM
Sorry its a '98
Old Dec 2, 2009 | 09:16 PM
RonJon's Avatar
Pull a fuse.... Same as my 2000, LEDS soldered in there.
Old Dec 3, 2009 | 12:51 AM
ABN31B's Avatar
yeah sorry. yank the fuse = kills the system. then after you get her through, go through the steps in the linked thread to get rolling RIGHT again.
Old Dec 3, 2009 | 10:42 AM
pulled the fuse and the light stayed on it just blinked when i started it up but eventually just stayed on.
Old Jan 28, 2021 | 12:39 AM
Monkeywrench71986's Avatar
Monkeywrench71986 is on a distinguished road
yeah no tried this w my wifes 03 and its been constant till today found a broken ground wire in this case, ground connections for each side are inside core support under headlights and a small one side of frame horn on drivers side just behind front bumper/fender support brace. Also check the connectors for corrosion and or oil antifreeze as both sensor lead/sensors are just in a position for contamination. I would scan first and go from there.
ChevyBlazer4uHaters
Sep 23, 2014 09:46 PM
Tenthjester65
Apr 24, 2014 05:39 AM
ChevyFamily
Apr 17, 2011 02:53 PM
Jones98
Dec 23, 2009 01:38 PM
98BlazerLT4x4
Apr 21, 2008 01:42 PM
