int light
Old Apr 23, 2014 | 09:18 PM
Tenthjester65's Avatar
Tenthjester65 is on a distinguished road
Question int light
I have a 2001 2dr when i got it it had the interior light thing ...i think its called a courtesylight. Where it comes on when you pull door Handle or pull key out. Does anyone know how to set this and what fuses Go to it. Also what fuses Go to my reverse light and how di i check bulbs
Old Apr 23, 2014 | 11:05 PM
cleburne red's Avatar
I believe the fuse for the courtesy lights would be labeled in the fuse box. The reverse light should be labeled on there somewhere, too.
To check the bulb, use your multimeter, and make sure you have continuity through the bulb. If there's an open, the bulb is bad.
Old Apr 23, 2014 | 11:16 PM
richphotos's Avatar
Not sure about the courtesy lights.
As for the reverse lights, pull the bulbs and look for blackening on the inside of the bulb, also look at the filament to see if its broken.
Old Apr 24, 2014 | 05:39 AM
Question
Okay i checked all those fuses and all looked good i Have to Remove Bracket for the actuator for tail gate to check bulbs and as for the dome light or courtesy light thing may i Don't have everything set correctly For them to come on when i remove my key or grab door handle?
teamrojas
Jan 21, 2013 12:30 PM
TDS-MN
Oct 29, 2012 07:19 PM
jkmzr201
Jun 12, 2011 11:16 AM
shade tree
Feb 4, 2011 08:26 AM
damageinc98
Jul 12, 2010 10:47 PM
