Air Conditioner Fan Setting #4 quit
Old May 8, 2014 | 12:28 PM
Mike F in Nebraska's Avatar
Mike F in Nebraska is on a distinguished road
Default Air Conditioner Fan Setting #4 quit
The air conditioner/Heater fan setting #4 quit working yesterday in my 1998 Blazer. The other 3 settings still work.
What does this mean? Can I expect the other 3 to quit soon?
Generally does this mean the switch is bad? Fuse? or does the fan motor need replaced?
What are the costs? How hard is it to change? I have replaced the radio before so I know how to take the dash apart.
Any information will help.
Old May 8, 2014 | 12:54 PM
newguy's Avatar
Probably the switch
Old May 8, 2014 | 01:46 PM
High speed is a direct 12v feed to the fan motor through the blower motor relay. Swapping the relay with another on like it is a quick and easy diagnostic test. If that doesn't cure it, then you will need to test the voltages at the relay to see if the switch is working properly.
I seem to remember the relay being located behind the glove box.
Old May 9, 2014 | 01:44 PM
When you say relay, are you talking about the resister that is inside the firewall under the hood?
Old May 9, 2014 | 01:54 PM
jpimp's Avatar
jpimp is on a distinguished road
No. High speed is a direct 12v feed through a relay behind the glove box. This bypasses the resistor in case the resistor fails, you would still have high speed fan to defrost the windshield for safety.
Old May 10, 2014 | 06:32 AM
Stupid question, how do you get behind the glove box? I see there is a latch holding it but I do not want to break it.
Old May 11, 2014 | 02:20 PM
wlevis76's Avatar
wlevis76 is on a distinguished road
Mike - this happened to me on my 2000 blazer. The relay is located in the engine compartment on the firewall. About $25 at Advanced Auto... 2 minute fix.
Old May 12, 2014 | 01:08 PM
Thanks
Old May 15, 2014 | 09:30 PM
I changed the relay today and now everything works. Thanks for all the help.
Old Aug 2, 2014 | 06:25 PM
ndgrown's Avatar
ndgrown is on a distinguished road
sounds like the resister is bad
dconnor.cfh
Apr 7, 2012 10:48 AM
jojocarreno
May 27, 2011 12:27 PM
ktallman
Dec 16, 2007 08:01 AM
brock
Jul 12, 2007 06:14 PM
sbranch
Mar 20, 2006 02:25 PM
