Air Conditioning Question 2000 Blazer
Old Aug 12, 2016 | 05:21 PM
Jimmer's Avatar
Jimmer is on a distinguished road
Default Air Conditioning Question 2000 Blazer
2000 chevy blazer ac replaced cycling/low pressure switch and connector had ac for 30 mins while parked in driveway. Pulled out of driveway and ac stopped functioning within a couple of minutes.
Is there a common electrical issue I should check for,
Shut truck off and star a few hours later and the ac works.
Also might be related, occasionally on startup high beam indicator is on, however I only have marker and taiights no headlights. They will come on by themselves eventually.
I found if I tap the main fuse panel under the hood on the drivers side the headlights come on and the high beam indicator goes of, I assume a bad ground, looking for suggestions
Thanx to all who might take the time to respond.
Old Aug 16, 2016 | 06:53 AM
Tajohns34's Avatar
did you replace the O ring when you did the switch? If you didn't it may have leaked refrigerant out and it could just be coincidence that it stopped when you moved the car.
Jimmer
May 31, 2017 11:18 PM
Onyx
Jul 21, 2016 11:13 PM
jaystoy
Sep 27, 2012 08:24 PM
roccorizer
Jul 22, 2009 03:55 PM
garlendrix
Jul 18, 2009 09:56 AM
