Air Conditioning woes...
Old Sep 28, 2009 | 12:45 PM
kinson33's Avatar
kinson33 is on a distinguished road
Default Air Conditioning woes...
Just inherited my grandpa's blazer, been mostly sitting for the past 4 years.
I've charged the freon twice now, re-checked and the pressure is back down to nothing both times. Obviously I'm not blowin any cold air. Do I have a leak or is that a compressor problem? Definitely need that AC with leather seats in south texas.
Old Sep 28, 2009 | 12:52 PM
It definitely sounds like you have a leak. If the compressor were not, well, compressing, the system would maintain the pressure you put into it.
Most of the refrigerant now available has UV dye in it. Get our your CSI light and glasses and have a look around all of the hoses.
Old Sep 28, 2009 | 12:53 PM
rriddle3's Avatar
I'd say you have a leak, but where it is, only a test can tell. Have an a/c man run a dye test to locate it.
And, once again, Fast-Fingers Kyle beat me to the answer.
Old Sep 29, 2009 | 11:26 PM
kinson33's Avatar
Turns out the compressor itself is leaking... I though the green looking stuff on the compressor was just from sitting for so long up in VA.
So... should I just put on a new compressor myself and recharge it or buy the whole kit and have them flush it?
Old Sep 30, 2009 | 06:11 AM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
I'd wait til it all leaks out again and it oughta be safe for you to change out the compressor, make sure you put the right amount of oil back in the new one before you install it, after that you will need to pull a vacuum on the system to charge it, might be easier just to swap out the compressor and let an ac shop recharge it
Old Sep 30, 2009 | 09:23 AM
kinson33's Avatar
Originally Posted by Jason Rebellion
...might be easier just to swap out the compressor and let an ac shop recharge it
Thats what I was thinking to do because I know I could handle that much, haven't done too much work under the hood with my cars but I'd like to think I'm mechanically inclined.
Just wasn't sure because all the parts stores and shops say to replace with the whole kit (drier and orifice tube) otherwise the warranty on the compressor is void.
Old Mar 29, 2010 | 01:16 AM
cooper232's Avatar
cooper232 is on a distinguished road
so if there is green stuff on the a/c system thats from it leaking? i have green mold looking stuff all over the canister on the passenger side near the firewall.
Old Mar 29, 2010 | 07:10 PM
1998MSO's Avatar
1998MSO is on a distinguished road
I suggest if you replace your compressor you also replace the accumulator and orifice tube as well. The accumulator has a desiccant inside to absorb moisture and if the A/C hasn't worked in 4 years, you should change it. Contamination can also plug up the orifice tube and that will make a huge difference in how well the A/C performs. Both the accumulator and orifice tube are inexpensive and easy to replace.
DCFluX
May 16, 2008 09:20 PM
DrThorsen
Apr 14, 2008 10:46 AM
KaptainKen
Mar 23, 2008 05:03 PM
DCFluX
Oct 5, 2007 06:28 PM
myboo11009
Aug 22, 2006 04:21 PM
