air vents
I had the same problem on my 95 Blazer, the PCV valve was bad. My mechanic claims the vents get the vacuum source from the PCV valve and if it goes bad anything else vacuum operated will not work correctly.
If the vacuum to the control switch in the dash is "fine" (i.e. measures the same or close to the same as idle vacuum on the motor, then the vacuum system is operating properly.
To the OP, please provide your vehicle information.
scoot
01-08-2007 08:48 PM
