Air vents blocked, or is it vacuum leak?
Old Dec 19, 2007 | 10:56 AM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default Air vents blocked, or is it vacuum leak?
my heat and my AC only blow through my defroster and floor vents, what could the problem be? is it a vacuum leak?
Old Dec 19, 2007 | 12:04 PM
magtec's Avatar
magtec is an unknown quantity at this point
Default RE: Air vents blocked, or is it vacuum leak?
most likely a vacuum leak. i was able to hear it in my truck and trace it to a spot behind a kick panel under the dash on the passenger side. see the grey vacuum line?
Old Dec 19, 2007 | 12:43 PM
Yup, loss of vacuum to the HVAC control head. Quite possibly could be caused by a faulty vacuum switch on the transfer case allowing transfer case fluid into the vacuum system... Hope its not that, but I've seen it before.
Old Dec 19, 2007 | 01:49 PM
Jharper's Avatar
thanks for the help, i should be on the road here soon, so when i get the new motor in ill be sure to check that out and see if thats the problem. i just have some down time right now and i was just trying to fix a few of the minor issues i had, thanks guys.
Old Dec 19, 2007 | 08:47 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
i had the almost same problem on my s-10 i had. it would blow fine till i got on the gas real hard and it would start coming through the defrost and floor, oncei would back off it went back to normal
Xipher
23
Mar 28, 2015 10:15 PM
RockyMountainHermit
Sep 20, 2014 06:29 PM
Jeru
Oct 20, 2009 08:09 PM
Patrick_Boyle
Aug 17, 2008 06:10 PM
