Airbag light B1061
hey guys I have an airbag light on and I read the code its a B1061 and to my surprise, with the search button, its a new one on here!
In the RUN position, the ignition switch applies battery voltage to the AIR BAG warning lamp and to the IGNITION POSITIVE VOLTAGE input terminal 10. The inflatable restraint Sensing and Diagnostic Module (SDM) responds by flashing the AIR BAG warning lamp seven times. The SDM monitors the lamp driver output by comparing the output state at the SIR INDICATOR terminal 7 to the microprocessor commanded state.
Conditions for Setting the DTC
The output state at the SIR INDICATOR terminal 7 does not match the commanded state of the lamp driver for 400 milliseconds.
The CONTINUOUS MONITORING test checks for this DTC. This test occurs when IGNITION 1 is within the normal operating voltage range.
Action Taken When the DTC Sets
• The SDM sets a diagnostic trouble code.
• The SDM attempts to turn on the AIR BAG warning lamp.
Conditions for Clearing the DTC
• Current DTC
The output state at the SIR INDICATOR terminal 7 matches the commanded state of the lamp driver for 400 milliseconds.
• History DTC
- You issue a scan tool CLEAR CODES command.
- 250 ignition cycles have occurred without a malfunction.
Where in the world do I start to fix this?
• Current DTC
• History DTC
Jonboy
03-12-2012 07:08 PM
aaronjohn20
03-21-2008 07:00 AM
