Alternator
Old Jan 13, 2015 | 06:58 PM
raysrh's Avatar
raysrh is on a distinguished road
Default Alternator
The battery was dead on my '99 Blazer this morning so I jumped it but as soon as the jumpers were disconnected it died. So I put another battery in it and it started but the alternator is only charging at the first large line to the right of the the 9(bottom). I guess that would be 12V? When revved up it gets to 14. My headlights are on all the time if that means anything. So is my alternator shot or is this normal? The battery that was in the car was fairly new and the cables and connections are good. I found no reason for the battery to be dead(lights on, etc.). ???? So since I posted this I've determined that my alternator is bad. I called to see about a replacement and it seems there are several types, that is amps. How can I tell what amp it is? Well nevermind on this post, I already found out all I need to know.
Old Jan 14, 2015 | 03:36 AM
newguy's Avatar
you need to check with a real volt meter. Gauges aren't that accurate. Engine running it should be over 13v.if so alt is good.
Old Jan 17, 2015 | 09:37 AM
jimspahr@msn.com's Avatar
You can get a DVOM at Harbor Freight Tools for 4.99. Set the DC range at '20 VDC' and you should read 13.7 VDC +- 0.1.
Old Jan 20, 2015 | 07:56 AM
Tajohns34's Avatar
are you running anything that isn't stock? Amps, efans, extra lights or anything like that?
2001blazer
Nov 3, 2005 01:13 AM
2001blazer
Oct 24, 2005 09:15 PM
blazer1
Jul 25, 2005 05:04 PM
ThisSideUp
Jul 18, 2005 04:51 PM
shawnCRX
Jun 11, 2005 03:47 PM
