Alternator / Charging Issue
Old Oct 17, 2019 | 04:18 PM
UK_'s Avatar
UK_
UK_ is on a distinguished road
Default Alternator / Charging Issue
Hi everyone,
I have just bought my first Chevy a 1999 UK spec 4.3 four door LT. Only had it a couple of days and about 200miles when the charge light came on. I have done some very basic testing as there is not much to test on the two wire alternator. Basically main B cable is good, ground is good but I don't know what the small red wire on the L terminal should be showing. Is it a PWM signal or is it direct to the charge light/resistor? The symtoms are basically the alternator appears to be giving no charge at all.
Thanks for any help..
Old Oct 17, 2019 | 09:10 PM
In the states, our auto parts stores will have test benches on which an alternator that is brought in can be tested. Could you do that there?
Old Oct 18, 2019 | 12:48 PM
GeorgeLG's Avatar
On an alternator of that year I believe that the "L" terminal is an output to the PCM to turn on the dashboard charging light. The alternator and its internal regulator are a self contained voltage system. What is the system voltage when the truck is running?
George
Old Oct 20, 2019 | 06:03 PM
UK_'s Avatar
UK_
Hi,
Thanks for your replies. Alternator testing is not common here. Most places just sell/fit new parts and hope the problem is fixed.
I was happy with the battery cable connection and also the ground connection. Just not sure what I should be seeing on the L wire. The running voltage was a little less than engine off battery voltage so the alternator seemed to be doing nothing.
Anyway I took a chance and ordered a used item from ebay and this is working fine so I'm happy with that.
Steve
Bob Tour
Dec 16, 2018 05:50 AM
ralbon
Feb 11, 2014 08:56 AM
tipshoe
Jan 23, 2013 11:27 AM
appliancguy
Aug 16, 2011 09:27 PM
brudus420
Apr 29, 2011 06:37 PM
