alternator charging problems
Old Mar 31, 2011 | 12:11 AM
brudus420's Avatar
brudus420 is on a distinguished road
Default alternator charging problems
here`s what i got: 1994 Blazer, 350 engine, here`s the problem: the new alternator wont charge.
Old Mar 31, 2011 | 08:56 AM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Check to see if the belt is slipping at all, check connections, and in some rare cases they stick a pin in the backside to keep the brushes from contacting till you install it. don't know why they do this, but they did for the last one I got.
Old Apr 2, 2011 | 08:39 PM
brudus420's Avatar
I took the wire off the wire off the post that runs to the Battery from the alternator started my truck and the i have 1-volt off the alternator? I guess my new alternator is fried... Thanks though, that was a good idea about a fuesable link from altenator to battery.... I Like this Web-Site and being part of it......
Old Apr 3, 2011 | 09:31 AM
helo's Avatar
helo is on a distinguished road
see if the exciter wire (the thin red/pink wire on the 4-prong plug, wire #3) has 12v with ignition on. If not, that's your problem and the alt is fine.
Old Apr 4, 2011 | 12:26 PM
brudus420's Avatar
wow,I tried averything i put 2 alternators on it, pulled it off &tested it "good alternator" tried new wire from alternatir to battery??? im stumped???? The 4-way plug that goes to the altenator only has 1 wire brown???
Old Apr 23, 2011 | 10:15 PM
brudus420's Avatar
How can i post pics, The mudein Season is Here... Like to post pics of Chevys pulling out F150s.... lol.... ;o}
Old Apr 29, 2011 | 06:37 PM
blazergurl95's Avatar
blazergurl95 is on a distinguished road
id like to know if you fixed your problem? I have the same problem, my alternator wont keep a charge. the plug i have also has a brown wire, but it also has a red/pink wire that is not hooked up. i have looked everywhere to try to find out where it goes but no luck.
74shark
Oct 14, 2014 03:26 PM
Curt8153
Jan 2, 2014 06:48 AM
odfareal
Nitrous, Super Chargers, & Turbos
Oct 26, 2009 01:36 PM
blzn95
Jan 27, 2009 08:48 AM
wetdog
Dec 15, 2008 05:39 AM
