Alternator pm?
Old Dec 20, 2013 | 04:39 PM
KEA2300's Avatar
KEA2300 is on a distinguished road
Default Alternator pm?
I have a 2001 with 185,000 miles. I have replaced a number of items like plugs, wires, hoses, waterpump, belt, etc. as PM items. I'm looking for suggestions as to when I should replace the alternator as opposed to letting it die and putting me on the side of the road 50 miles from home.
Old Dec 20, 2013 | 05:39 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
theres isnt a set mileage or time frame they will last. they will last until a bearing fails, the brushes wear out, or the regulator fails. id say 5 to 10 years is a reasonable time. sometimes new ones will fail out of the box or shortly after or they could last 20 years. i would run it till you notice sounds coming from the ALT or lights don't seem as bright
Old Dec 20, 2013 | 09:40 PM
GaBear's Avatar
GaBear is on a distinguished road
A couple of things I've noticed over the years. If your lights flicker severely, Check the battery terminals. If they are clean and tight then the ALT is starting to go bad. If you hear a whinning sound when you start up in the morning Its usually a bad bearing in the ALT Check to make sure the belts are not too tight if not Change it.
Old Dec 20, 2013 | 11:52 PM
cctcct67's Avatar
cctcct67 is on a distinguished road
you could always have it rebuilt by a trusted rebuilder. If he is good he will check all parts, replace worn parts and test it before you get it back in hand.
2001blazer
Nov 3, 2005 01:13 AM
2001blazer
Oct 24, 2005 09:15 PM
blazer1
Jul 25, 2005 05:04 PM
ThisSideUp
Jul 18, 2005 04:51 PM
shawnCRX
Jun 11, 2005 03:47 PM
