Am i doing this right.
Old Mar 8, 2009 | 08:49 PM
hernandez3674's Avatar
hernandez3674 is an unknown quantity at this point
Default Am i doing this right.
Hi guys.. I have a 97 blazer and my wife has a 2000 jimmy.. anyways i picked up a snap on fuel pressure gage so off course i wanted to try it out.. So i screw the fuel gage to the valve and turn the ignition on to prime and there is no pressure. Im thinking i got screwed with the gage. Well, i started the truck and the pressure goes to about 58 psi. I shut the engine off and the gage instantly goes to Zero... Now i am confused. .. Well, wondering what was going on, i screw the gage to my wifes truck... it primes to like 55psi.. i start it and its about the same alittle more.. and shut it off and it stays constant.... What is wrong with what i did.my truck runs fine .Is the procedure different for both? Last year i replaced the injectors with the new design, and two years ago installed a replacement carter pump but i have no problems. Thanks for your help.
Old Mar 8, 2009 | 11:15 PM
rriddle3's Avatar
Are you sure you were holding your mouth right?
Seriously, I can't imagine why it was reading on yours like that if the truck is running correctly. I would test it a couple more times and see if it does the same.
AJBert's Avatar
Is it possible you screwed it in on the down stream side of the regulator?
Old Mar 9, 2009 | 03:46 AM
I connected it the the valve near the distributor . It is on the same location on both vehicles . It has a black cap. I will try it this afternoon once again..
Kipper667
Jun 2, 2013 01:16 AM
kikkegek
Tires and Wheels
20
Oct 12, 2009 08:04 AM
2klt
May 20, 2007 09:57 PM
redpeppers
Apr 7, 2007 04:55 AM
supermancs
Jun 5, 2006 04:46 PM
