Another dumb A/C question
1999 Blazer A/C not working at all for about a year. Compressor does not come on. I tried charging last year but it was not needed, I have a $100 A/C gauge set and they are showing good, maybe a little high (a year ago).
I replaced hi (recently) and low (last year) switches, nothing.
I do need to check pressure levels again since I replaced the high pressure switch on compressor but what else can I do without getting the system evacuated.
I do all my own work, but I know I will have to get the A/C evacuated at a shop, how much will that normally run for evacuation.
I have the vacuum tool for A/C systems too, if I should I need it.
On most days I drive the vette (with A/C and better gas mileage) but I still love jumping in my Blazer and driving it whenever I wanna blend in or take the family (I hate riding in my wife's tiny purple Honda).
Thanks in advance for the help
Thanks, it must have all leaked out since I checked it last year. There was a tiny (1/2 second) little spurt of pressure when I removed the high side switch, but I assumed it had an internal schrader valve like the low side switch. I guess it would have all leaked out if there was any it then.
I guess I will check pressures and if there is no pressures I will replace some parts, vacuum system and check for leaks. Then I will go from there
I probably should have gotten out my 1000 page factory service manual, I keep forgetting I have one. Surely there is a no A/C diagnosis chart.
Thanks for the help
Hi all,
I'm in the process of changing the air con compressor in my '99 2dr and wanted to post a warning for anyone who finds themselves in the same predicament. Having just spent several thousand $$ on other repairs I decided to get the cheapest compressor I could find. Did a search on line and found a "Replacement" brand one (PtNo REPC191115) which claimed to be a direct replacement for my car. Long story short, it's not. I'll post the full story in a new thread, but just wanted to post this in a few existing threads so no one gets ripped off like I did.
-Scott
-Scott
OK so I replaced the (full of gunk) Orifice Tube and filled my system, now it works, YAY. The kids will be so happy.
Don't know exactly what was the main problem but I only recently bought the $20 high side switch and $2 orifice tube so it was likely one for those, probably just the orifice tuibe since it was caked full of junk.
Next spring i will have to buy a new accumulator, seals, etc. and give it a good leak fix PM
Now I gotta find a pigtail for my compressor because the wire is cracked inside right next to the plug end (cuts out sometimes), anybody know who has a cheap one available.
Charged my A/C in my vette too, now I'm good to go!!!
Thanks and later peeps
snakey
May 12, 2012 11:49 AM
dBsound
Feb 23, 2009 04:29 PM
