another hvac question
Old Apr 13, 2015 | 07:31 PM
  #71
er0ck273's Avatar
er0ck273 is on a distinguished road
Originally Posted by Captain Hook
You have checked all of the vacuum lines at the mode switch connector, and they all checked good, (this also checked the actuators). You checked the plastic line from under the hood to the mode switch connector, and it checked good. If it leaks vacuum on any position when testing from under the hood, the mode switch is definitely the problem.
do you think the new one I got was faulty from my test on it when it went to where the black line enters in came out of port 3 i believe? (off position i believe you said nothing should flow out)
Old Apr 13, 2015 | 07:35 PM
  #72
Definitely a faulty mode switch. When you apply vacuum to the source port, (black) and select the BILEVEL position, it must hold vacuum.
Old Apr 13, 2015 | 07:38 PM
  #73
er0ck273's Avatar
may as well just get a new one now, my girl being a student i can get 2 free day shipping from amazon
to get a tad off topic, while taking a vacuum line off for testing, i broke the washer fluid hose tht goes to the front two, is there a part number for this or is it just a certain size hose i need?, also is there a connector to connect both lines where it split or should it just be replaced?
Old Apr 13, 2015 | 07:42 PM
  #74
Snip out a small section and take it to an auto parts store. Get a section of rubber hose that the plastic fits snugly inside of. Splice it back together.
Old Apr 13, 2015 | 07:54 PM
  #75
er0ck273's Avatar
im trying to imagine if the small rubber hose would compress inside of there and clog it. think i could get away with a plastic connector kind of like the ones with the vacuum pump...yet i wouldnt know what size to get
Old Apr 13, 2015 | 07:58 PM
  #76
The existing plastic tube will go inside of the rubber hose.
Old Apr 13, 2015 | 08:07 PM
  #77
er0ck273's Avatar
ahhh i gotcha! a little relieved i dont have to take the washer fluid reservoir out, I am gonna re-order the part and will test it before i take any of the dash apart
specialty8
29
Jan 24, 2023 10:35 AM
c3mp69
May 13, 2011 01:30 AM
chrishorton74
Jun 2, 2010 09:03 PM
kota04sxt
Dec 10, 2009 09:34 PM
blazin_j
Oct 7, 2009 08:25 AM
