Another two questions....
Old Sep 6, 2011 | 09:04 AM
jlg822's Avatar
jlg822 is on a distinguished road
Default Another two questions....
1) my heater in my 1998 blazer lt 4x4 won't work. is it the heater core? or the condenser?
2) i need to replace the grill and headlights is it something i can do myself? and replace the fog lights... need some advice...
Old Sep 6, 2011 | 09:26 AM
coolasice's Avatar
coolasice will become famous soon enough
what part of your heater won't work? blower not blowing air? check fuses?
Old Sep 6, 2011 | 10:41 AM
TheRandom1's Avatar
1) Need more information on your heater... does it blow anything, not at all, only certain settings, etc? As detailed as possible.
2) If you know how to use a screwdriver, then yes, you can absolutely do this yourself. As far as advice... advice on what exactly? How to replace them? What to replace them with? Where to buy parts?
Old Sep 7, 2011 | 05:07 PM
jlg822's Avatar
It blows cold air out when it is on heat. I'm wondering about the water pump or thermostat?, also yes lol I have a screwdriver.... I will look into those parts
Old Sep 7, 2011 | 05:18 PM
It is possible that the blend door actuator isn't functioning and is locked into the cold position. Do you have manual hvac controls (just blue & red around the temperature control ****) or automatic (numbers around the temperature control ****)?
To remove the grill, locate the spring clips that fasten the grill into the radiator core support. Use a large flat head screw driver to quickly release the spring clips by placing the screw driver blade between the spring clip & the core support & twisting the blade. For the ones under the headlights, gently pull (don't tug) on the grill. The turn signal / fog light assemblies are mounted in the grill so you will have to remove the bulb connectors prior to completely freeing the grill.
Old Sep 7, 2011 | 05:22 PM
pettyfog's Avatar
Thumbs down
I'm 68 yo, so I dont really care if people think Im 'kind' or not.
Could you POSSIBLY be any MORE obtuse while asking for help?
You supposedly know how to operate the heater controls. Or do you just punch a button twist a **** and hope for the best.
You MIGHT add such trivia as does the air blow out proper SELECTED vents.. does it cool well on AC position... Just because we're nosy!
- First answer.. if it's been that way a while and your truck engine hasnt grenaded yet, it is most likely not the water pump or thermostat. Assuming your temp gauge reads in the normal range and gets there within five minutes of driving.
1. HTF would we know... there are a few people here who could disassemble the trucks down to bolts and nuts and put them together again, yet never did it before.
but
2. judging from your subsequent posts, probably not.
______________________________________________
Okay.. NOW.. start your truck from cold. When the temp gauge gets about halfway to normal operating position, feel the hoses going into the firewall. Or feel the pipe nipples they hook to if you can touch them
Are they both warm?
Turn blower on high with temp on heat-warmest. Wait about a minute. Are they still both warm and same temp?
Old Sep 7, 2011 | 05:39 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Originally Posted by pettyfog
Have a beer man...
Old Sep 7, 2011 | 06:33 PM
pettyfog's Avatar
Originally Posted by Little Roober
Have a beer man...
Guy goes to Doc
"Doc, my arm hurts. What's wrong with it?"
"When does it hurt?"
"When I'm awake"
JasonGoneFishing
Nov 22, 2014 05:34 PM
The_Beast
Mar 27, 2010 06:32 PM
moldeck
Nov 23, 2009 05:57 PM
bezerker
Nov 9, 2009 04:00 PM
1muddybowtie
Feb 27, 2008 07:32 PM
