Another Vacuum Thread But I Actually Searched First
Old Nov 30, 2020 | 11:20 AM
Mack_Murray's Avatar
Mack_Murray is on a distinguished road
Default Another Vacuum Thread But I Actually Searched First
Howdy everyone. New user/blazer owner. I recently purchased a 01 ZR2 that needed a fuel pump and some other minor things.
I’ve got it running and driving but ever since I first purchased it there has been the lovely hiss of a vacuum behind the dash.
It made the noise on every setting including off and the only time it faded was when I was under acceleration.
I pulled the dash apart yesterday and got the HVAC controls out. I found that the black vacuum “switch” where all the lines meet was were the hiss was originating.
So I’m going to replace that part but I wanted to consult with some others who have more knowledge of the system. As far as I can see there is no fluid in my lines as well. Is this a common problem on these? Or is there a deeper issue causing this to function improperly.
Old Dec 2, 2020 | 09:37 PM
So I got around to replacing the vacuum switch and my hiss is no more. The doors don’t seem to fully actuate how they’re supposed to, seems that I still get air out of every vent but it diverts enough that I’m not going to worry until it doesn’t function properly.
Old Dec 3, 2020 | 05:44 PM
LannyL81's Avatar
Good that you fixed the HVAC vacuum leak...however have you replaced the vacuum lines under the hood? Easy and pretty cheap to do. Just purchase a length of bulk hose, reuse all the fittings. Also suggest checking the reservoir that I believe is inside the front left fender. Use a hand vacuum pump at the reservoir slip-on fitting, see if you can pull a vacuum on it and it holds. Also there should be a check valve in the lines somewhere, make sure it is not leaking and working.
Blazer 98
Mar 21, 2014 04:14 PM
AintQik
15
Nov 4, 2012 04:52 AM
jaybird33081
Apr 21, 2012 04:57 PM
Crazyc775
Mar 17, 2012 08:00 AM
dashyman
Dec 14, 2005 11:28 PM
