Would a A/C delete throw a check engine light?
Old Dec 3, 2020 | 12:09 AM
01blazer4.3's Avatar
01blazer4.3 is on a distinguished road
Default Would a A/C delete throw a check engine light?
I recently got my 01 blazers 4.3 rebuilt and ditched the whole A/C system because some backyard mechanic tried to fix it way before I got it. I deleted the A/C with a dorman A/C bypass pulley and pulled the A/C relay and fuse I just tucked the A/C connectors back and zipped tied them to the rest of the harness. Only problem is I have the check engine light on now. I’ve read that misfires are common on these but I replaced the cap and rotor so I don’t think it’s the ignition system throwing the code. Any help before I go and buy a scanner would be much appreciated.
Old Dec 3, 2020 | 01:11 AM
GeorgeLG's Avatar
Can’t do much without the codes. An auto parts store can pull them for you but you can get better capability than them for a modest investment. I can’t think of any reason why the AC delete would cause a code, I don’t think the system monitors the compressor circuit.
George
Old Dec 6, 2020 | 09:06 PM
Thank you for the reply. I went out and a scanner and ran the code today it out to be a P0418 secondary air injection system relay. I thought I would have to replace the air injection system but I did some further research and I believe that I’m just going to have to replace the relay. It’s a $25 part at autozone that I’m going to get tomorrow before work.
Old Dec 6, 2020 | 09:44 PM
GeorgeLG's Avatar
There is more than one possibility:
https://www.obd-codes.com/p0418
If you want to rule out the relay, swap with another identical known good relay from the fuse box if available.
George
thog472
Aug 14, 2020 06:51 PM
aconnerb
Jan 12, 2014 03:12 PM
filoblazer
Mar 17, 2012 04:10 PM
mxtmanx5
Sep 26, 2010 02:30 PM
grejef
Feb 15, 2007 10:04 PM
