Any Help appreciated
Old Oct 19, 2013 | 03:19 PM
jaded1's Avatar
jaded1 is an unknown quantity at this point
Default Any Help appreciated
So im not new to the group. I have researched this problem and cant find an answer. I have a 95 s10 blazer. I have replaced the plugs,wires,egr,cap and rotor, and now cat,02 sensors and exhaust. Car started up and ran like a brand new vehicle but after 10 minutes of running the new cat started to glow red and the car started to bog down and run like crap. I have tested the fuel system, and it running right where it should be. Any assistance would be great.
Old Oct 19, 2013 | 04:31 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
U got a cat...... Plain and simple
Old Oct 19, 2013 | 07:18 PM
LannyL81's Avatar
What brand of O2 sensors did you use? Perhaps the PCM/ECM is not reading the new O2 sensors correctly.
Try removing the O2 sensor from the exhaust system, leave it electrically connected and see if the engine runs better after 10 min or so. This will set the Check Engine Lite as the PCM/ECM will not see any change in the O2 sensor readings...so sets an error.
But if the engine runs fine, then possible the new O2 sensor is faulty.
WMWilson87K5
Sep 21, 2012 01:14 AM
curtnastyy
Apr 19, 2011 11:53 AM
BlazerPunisher
Mar 23, 2009 05:47 PM
jennikz
Feb 15, 2006 12:30 PM
