Anyone know the function of a spider injector??
Recently, I had to do a fuel pump job on my 98 Blazer 4x4. That job is done but I suspected there to be another reason for it not starting. When I tested the spark on the plugs it wasn't getting a spark I replaced all the plugs, checked the new wires, changed the coil ignition, replaced the distibutor rotor, battery tested good, alternator is fine and the starter is new, Someone mentioned the spider injector could be bad... does anyone know the function of it and if it could be the reason why I'm not gettin a spark.
Any leads would be appreciated thanks,
truckstuff216
truckstuff216
Thanks for the tips Im pretty sure its not my spider injector. Im just looking to bring the spark back. ill try the crank sensor first.
where would the ignition control module? is it the mini electrical component attatched to the coil? and is there a forum specifically for ''no spark'' on this site?
Thanks,
truckstuff216
Thanks,
truckstuff216
Last edited by swartlkk; 03-30-2010 at 08:19 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
newguy
03-22-2013 09:36 AM
bigdaddykane93
43
01-21-2010 12:12 PM
JeffUSMC
01-16-2010 12:53 PM
