Automatic Seat Memory
Old Jul 6, 2009 | 08:46 PM
littleblueblazer's Avatar
littleblueblazer is an unknown quantity at this point
Default Automatic Seat Memory
I have a 2000 Blazer. When I use the remote door lock, the drivers seat goes back to a complete recline position (only when unlocking the door). It doesn't matter which remote we use, driver 1 or 2. Any suggestions for this problem? Thanks for your help.
Old Jul 6, 2009 | 08:59 PM
Does it return to the programmed position when you hit the memory 1 or memory 2 buttons?
Old Jul 7, 2009 | 07:52 PM
The 2 memory buttons does not bring the seat back into position.
Old Jul 7, 2009 | 10:07 PM
Have you programmed them? Does the programming stick? If not, you may have a faulty memory module.
Old Jul 9, 2009 | 08:05 PM
Where is the memory module located? Thanks
Old Jul 9, 2009 | 09:24 PM
Under the seat. It will have 3 connectors going into it.
Old Jul 10, 2009 | 02:00 PM
jstein's Avatar
jstein is an unknown quantity at this point
I'll 2nd that. On my mothers Bravada we had the same problem. There should be a procedure for setting the memory for seat position 1 and seat position 2. I think the steps we found in the owners manual. Hope this helps.
TonyZR2
Sep 26, 2014 05:26 AM
firewild
Jun 6, 2014 09:48 AM
LilMsChevy
Jan 11, 2010 09:45 PM
ehall
Nov 22, 2008 09:13 AM
Blazin_1t_up
Shows & Clubs
Oct 29, 2008 10:47 PM
