I'm finally doing a fluid change for the automatic transmission in my 2002, 2-door, 4WD Blazer. I order this AC Delco filter and gasket set from RockAuto, and the gasket doesn't line up with the bolt holes. Did I order the wrong part, or did RockAuto mess up? https://www.rockauto.com/en/moreinfo...84286&jsn=1645
My oil pan is 16 bolts. The gasket is 16-bolts. But they don't line up.
The filter itself seems to be the same form factor, but it is made of a different material than the original one I pulled out. The original is a black plastic all the way around. The AC Delco replacement I ordered is aluminum on the bottom side.
