Axle nut torque
Old Oct 4, 2009 | 11:13 PM
xtr1c0's Avatar
xtr1c0 is on a distinguished road
Haynes Manual says Through 1996 180
1997 and later 130
Old Oct 5, 2009 | 05:32 AM
Check your units. That is 180Nm and 140Nm which is 133ftlbs & 103ftlbs respectively. These values are from the FSMs. I found a set of 95 & 96 FSMs to obtain these values.
Old Oct 5, 2009 | 06:31 AM
xtr1c0's Avatar
I checked again and Haynes Manual states Ft-lbs. I'm not saying they are right, just what is in their manual. I am in the middle of a hub & bearing assy job so I appreciate the correct values. Thanks y'all.
Old Oct 5, 2009 | 06:44 AM
That's messed up right there. I just got done looking it up for another member and I checked from 95 through 2002, all years and they all came back with the numbers I posted above. Sounds like Haynes has their units messed up.
Old Oct 27, 2009 | 07:33 PM
rsturge's Avatar
rsturge is an unknown quantity at this point
depending on your bearing the torque spes may vary. you should always use the manufac torque specs. there have been alot of stories of people blowing out bearings after just a few months of driveing and torque is the most common falt.
myblackblazer
Mar 22, 2011 04:41 PM
Magmotor
Oct 20, 2010 09:45 AM
rdhoping72
Oct 6, 2010 07:42 PM
duckster_37
Mar 24, 2008 08:12 PM
Annekat91
Sep 23, 2006 01:05 AM
