Bad ignition switch ?
Old Nov 3, 2010 | 07:22 PM
joky327's Avatar
joky327 is on a distinguished road
Default Bad ignition switch ?
98 4 dr 4x4. Replaced engine and went to start it and had no warning lites except sel & airbag lites. I started it and none of the gauges worked.
Replaced the ignition switch and still have same problem. Been fighting this for a while. Put my obd tester on it and everything works. Take it off and I'm back to square one. Any help?
Old Nov 3, 2010 | 08:26 PM
franklin's Avatar
franklin is on a distinguished road
are you sure you got all of the ground wires back into place?
Old Nov 4, 2010 | 04:19 PM
joky327's Avatar
Default Still checking
Haven't found any but I did break a couple but I soldered them back. Hopefully I didn't miss one. Is there anywhere I can hook a ground wire to the gauges & warning lites to bypass it other than using my obd cable. Thanks
sacnfox85
Sep 21, 2014 05:20 PM
gaetz1985
Apr 3, 2013 10:21 PM
crater
Oct 30, 2011 10:16 PM
shade tree
Jan 31, 2011 12:50 PM
overseachevlover
Aug 9, 2009 04:17 AM
