Bad oil pump?
Old 11-11-2012, 01:48 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Bad oil pump?
A few months ago I replaced the head gaskets and since then I have had really low oil pressure and made sure that I have had oil in it. Last night after adding a quart I noticed that it was still knocking and showing low oil pressure on the gauge at idle. When I put everything together on the top end is there something that I could have done incorrectly causing a problem, like not installing the distributor correctly? How would I know for sure if the pump is going bad? Could I have some thing that is clogged?
Any info or help in general would help. Thanks!
Old 11-11-2012, 02:15 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Well I know if you have low oil pressure and its knocking its the bad bearing/bearings causing it.The only way that I know of that changing head gaskets would be antifreeze got into the oil.I hate to say it but you have to make decision either rebuild or replace the engine ot worst case scenario if you follow me.As for something being clogged in your oil filter it could happen,there a screen in the bottom of it and if its clogged your pump is going to pump the oil through the engine.
Old 11-11-2012, 02:26 PM
step66's Avatar
X2 to 1sttime. These 4.3s are plentiful at salvage yards and can be had cheap,but why spend $500 and a weekend swapping it out to find other issues:high mileage,intake gaskets and head gaskets could be bad on the salvage motor... If you really like the car and feel like keeping it,a rebuild is the way to go.If you are at all mechanical you can pull and reinstall it yourself and let the machine shop do the rest,still may cost $2,000+
Look into those shipped rebuilds from Indiana:Jasper. Best of luck!
Old 11-11-2012, 02:29 PM
Klturi421's Avatar
Aside from the obvious of pulling the engine and rebuilding, is there anything I can do to prolong it? Trying to hold out until I can buy a new car in a month or so. Or is it something that needs to be addressed sooner than later?
Would changing the oil filter tell me any at all? Are there any additives I can add to the engine to buy me some time?
Old 11-11-2012, 03:52 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
If your bearings became starved for oil due to the oil pump failure, there isn't much that can be done to prolong the engine life. The bearings went dry and its only a matter of time before the engine seizes up. If you pull the dipstick and there are little metal fragments, that would be bearing material.
Old 11-12-2012, 05:20 PM
Klturi421's Avatar
Would a bad oil pump be the reason why my pressure drops while at idle?
When driving it goes up to about 20 or so. On a cold start the pressure shows 40 then slowly drops.
Old 11-12-2012, 05:38 PM
Joshs4x4's Avatar
Joshs4x4 is on a distinguished road
Brand of filter in car now?
Old 11-12-2012, 05:49 PM
Klturi421's Avatar
If im not mistaken, I believe Fram as I have typically used fram in the past with no problems at all.
Old 11-12-2012, 06:52 PM
I'm pretty sure thats normal, oil pressure drops at idle since the rpms drop. It goes up as engine rpm goes up. A cold engine has higher idle rpms and that causes oil pressure to be higher.
Old 11-12-2012, 07:06 PM
Joshs4x4's Avatar
Change the filter to wix brand and don't use the orange can of death!
Quick Reply: Bad oil pump?
