bad squeek from front drivers side HELP
Old Jul 22, 2007 | 03:00 PM
redpeppers's Avatar
redpeppers is an unknown quantity at this point
Default bad squeek from front drivers side HELP
I have a 2001 GMC Jimmy, 4dr, 4wd, 4.3 vortec engine, Automatic. I have this anony squeek coming from the front drivers side wheel well. The noise is onlypresent when i hit bumps or if i rock the truck up and down. I have re-greased the ball joints, sprayed lubercation on each rubber bushing and i can not see any bushing that may be bad. Does anyone have any ideas on this one. Thanks!
Old Jul 24, 2007 | 09:50 PM
Taymacjack's Avatar
Default RE: bad squeek from front drivers side HELP
You could check if your valance or bumper is loose on that side. Just an idea.
Old Jul 25, 2007 | 01:46 PM
DBlaser_ca's Avatar
DBlaser_ca is an unknown quantity at this point
My 97 Chev Blazer did this when I first got it. In order for me to certify it and get the ownership transferred over it required a swing arm on the drivers side as well as both lower ball joints to be done. I'm betting that it's probably your swing arm that is causing the noise.
upmaine
Jul 9, 2012 12:31 PM
Wexinlo
Apr 6, 2011 11:35 PM
ooodavie
Apr 24, 2009 01:36 PM
bill4848
Mar 8, 2008 10:13 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
