squeek in front end
Old Mar 1, 2008 | 04:00 PM
bill4848's Avatar
bill4848 is an unknown quantity at this point
Default squeek in front end
I have a 2000 jimmy with 117,000 miles. The squeek ison thedrivers side. Ijust replaced theshocks, not the fix. It only squeeks when the wheelsare straight, turn them to either side and the squeek goes away, how ????? This narrowes it downto the steering, i hope. Any helpwould be awesome.
Old Mar 1, 2008 | 04:03 PM
thegr81's Avatar
Default RE: squeek in front end
Tie rod end would be my fist suggestion, inspect your tie rod ends on the steering linkage and see what condition they are in!!
Old Mar 6, 2008 | 09:05 PM
bill4848's Avatar
I just changed tho outer tie rod end and still squeeks. I think i'm gonna take it somewhere, i'm getting [:@][:@][:@]! Don't know what else to do.
Old Mar 6, 2008 | 09:23 PM
thegr81's Avatar
Is this a 4wd?? If it isn't I would possibly suspect a wheel bearing maybe. If its a 4wd then I would think its something with the axles possibly cause you said it squeaks when wheels are straight and when you turn it doesn't make the noise correct?
Old Mar 6, 2008 | 10:31 PM
TripleBlackBlazer's Avatar
Take a gander at your control arm bushings. They can rot out and cause a squeaking in the front but it is usually in all situations, not just in straightaways. Take some lithium grease and spray the heck out of them and see if that helps. If not, you now have well-lubricated control arm bushings!
Old Mar 8, 2008 | 10:13 AM
tgod's Avatar
tgod is an unknown quantity at this point
I had a squeekon thedriver side frontwhen I got out of my 2001 Jimmy. It would also squeek going over the slightest bump. Very annoying! I greased my lower ball joints first and the squeek went away. Then I greasedevery zerk I could find.
customwheels
Tires and Wheels
Jul 13, 2014 05:54 PM
tammikm
Jul 15, 2009 05:26 AM
jhoyle12
Jul 7, 2009 07:48 PM
ooodavie
Apr 24, 2009 01:36 PM
redpeppers
Jul 25, 2007 01:46 PM
