Battery - Cold Weather
Old Jan 18, 2007 | 08:50 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Battery - Cold Weather
Well the past 2 days when it was about 5 degrees out side I would go start my vehicle before I take off with it. Well when I start it I am just getting by, like the battery has just enough juice to start it once. I am worried about this because the battery is no more then 2 months old and it’s a 7 year guarantee battery. I know if I try and go to get it replaced they will test it and say its fine, but in that cold weather its killing it. I am not aware of any of my friends having this problem. Is this just because of the cold weather?
Old Jan 18, 2007 | 08:54 PM
Default RE: Battery - Cold Weather
What are the CA & CCA (cranking amps & cold cranking amps) of the battery?
Old Jan 18, 2007 | 11:06 PM
hillbillyinOhio's Avatar
well, i doubt that the beating on it with the new subs and amp are helpin it any, but have it tested anyway.
Old Jan 18, 2007 | 11:10 PM
blazinloud's Avatar
try letting it get a bit of a charge by shutting everything off before parking it.
thats what I've always done [:-]
Old Jan 19, 2007 | 12:44 AM
Well that past couple days I havent been using my amp or subs and my radio is down on low when I go to start it. I know that on the guage when I start it, it is at like 8 amps but once the alternator kicks in it goes up to about 15-16 and comes back down to the normal 14 after a little bit.
Old Jan 19, 2007 | 01:39 AM
20Blazer00's Avatar
The battery gauge in the dash does not read amps, it reads voltage...if you are dragging to 8 volts then you need to have the battery checked for bad plates...just because you bought it new does not mean that it hold up in the cold like you are experiencing...that is why they have a warranty...also have the altenator charging rate checked to see if it is keeping the battery up. Since todays altenators can't recharge a low battery have them both checked....it could be that your altenator is not keepin up with your amperage draw.
When you install high amp parts like power amps for speaker systems you put a load on their the engineers did not build into the SUV...
kmalysa
Jan 10, 2010 09:29 AM
88hurstolds
Jan 17, 2009 07:43 PM
jman_08
Dec 24, 2008 01:14 PM
jaredwaugh
Nov 8, 2007 03:49 PM
Scarecrow
Nov 9, 2006 01:13 AM
