Bearing, caliper ?
Old Jun 28, 2016 | 11:44 AM
Mltoys's Avatar
Mltoys is on a distinguished road
Default Bearing, caliper ?
I put new rotors and pads on front end of my 98 4wd blazer.
Just recently i have been hearing a scraping when turning right and when applying brake. Its just the left side. Yesterday i felt a more pronounced grinding feel.
I just pulled the caliper and rotor, all snooth still. Tried to check thehub for play but felt nothing.
Any advice will help, thank you.
Old Jun 28, 2016 | 12:26 PM
Dust shield may have gotten bent when removing the old rotor??? Just have to investigate to find the problem.
Old Jun 28, 2016 | 05:45 PM
Mltoys's Avatar
Thanks, so if i dont feel a wiggle holdind the studs could the bearing still be bad?
Old Jun 28, 2016 | 08:50 PM
Oh yes. If it wobbles it's definitely bad, but they can make noise without wobbling too.
Old Jun 29, 2016 | 08:01 AM
Mltoys's Avatar
Well i think i will be removing the hub to inspect it to make sure
Old Jun 29, 2016 | 06:51 PM
Save your time and energy. Each hub assembly has two sets of ball bearings inside. If there's a problem with one or both of them, you'll need a stethoscope to determine which hub is noisy.
Old Jun 30, 2016 | 08:14 PM
Mltoys's Avatar
If i am taking it off may as well replce both sides.
Old Jul 1, 2016 | 08:21 AM
Tajohns34's Avatar
If you are replacing them don't buy cheap bearings unless you like replacing them on a regular basis. I did both of my fronts with MOOG hub and bearing assemblies.
Old Jul 2, 2016 | 07:56 PM
jimspahr@msn.com's Avatar
I certainly agree with Tajohns to go with a top quality hub bearing such as Moog's top brand. I don't see replacing both unless both are bad or you can't tell for sure which one is bad. Sometimes that is difficult to do. IOW I am saying replace the one that is broken.
Old Jul 3, 2016 | 06:45 AM
Mltoys's Avatar
Thanks, the noise is definately from the left side. I will change that hub this week.
I just hope that is the problem. The abs was acting up on that side also which i read can be caused by a bad bearing.
