Is this below normal operating temperature - pic inside
funny - mine sits the same spot too and i have gooood heat. like say 5 min down the road heat's working, 10-15 min down the road heats off cuz i can't standz it no moar. but ya my thermostat sits around 70 ish degrees C all the time unless i giver and she gets warmer @ low idle afterwards.
did the last thermostat in 5 minutes after getting back from the parts store (40 minute round trip). never lost more than 1/2 liter of coolant.
2 days before Christmas (a few years ago), in a snow storm @ -5*, & the converter locked up just fine on the 1 1/4 hour drive home (all highway)
Like 95Jimmy asked, is the heater putting out normal heat, if so, it may simply be a faulty guage or sender unit.
If/when you do replace the thermostat, just before putting the new one in place, bring the coolant level back up to the top of the thermostat flange. This will eliminate some of the problems of bleeding the air out of the cooling system.
hmm odd, like i said mine sits right between the first and second tick, rarley ever makes it to 100....so im guessing i probably sit around 85-90....last time i hit 100 i was driving up a mountain (and my stainless exhaust tips changed colour for the 2 inches from where they were welded to the exhaust pipes)......and i have great heat with it running at that.
as for the torque converter mine does not lock up when its cold (and i mean cold as in -15 or colder)....i notice that once the engine warms up enough that the oil pressure drops and returns down to normal pressure that is about the same time the torque converter will start to lock.
If it sn't blowing strong, then id suggest blower motor and blower fan. From previous experiance when id work on vehicles that had great heat but much blowing it was cuz the motor was going out causing the fan to not rotate as fast, resulting in less then good blown heat. Might be different with blazers though, but thats my experiance of it.
