Big problem with timing
Hello everybody,
I have problem with my gmc jimmy 2000 when I replace the lower intake gasket the distributor become different and its not start. So, I try to aligned but the problem is that I don't see mark on the harmonic balancer nothing is there. I also, sand it and clean it but no mark on it anyone know what can I do now ? |
Originally Posted by jimmy_for_ever
(Post 694694)
Hello everybody,
I have problem with my gmc jimmy 2000 when I replace the lower intake gasket the distributor become different and its not start. So, I try to aligned but the problem is that I don't see mark on the harmonic balancer nothing is there. I also, sand it and clean it but no mark on it anyone know what can I do now ? https://www.justanswer.com/car/1bz2b...two-marks.html |
no crankshaft balancer
Originally Posted by Lesmyer
(Post 694697)
Here you go. The marks are there. Good luck and best wishes for a successful repair.
(Post 694703)
There is no crankshaft balancer just a gap between the crankshaft pulley and timing cover
Do you mean there is no harmonic balancer on your truck?
(Post 694705)
https://blazerforum.com/forum/2nd-ge...e-87514/page3/ post#29 This is on my 2001. Will (should) be identical to your 2000. Guess the marks might actually be on the grooved pulley (I can't remember for certain) - but they are there.
Originally Posted by Nola 77
(Post 694712)
Can you post a pic?
(Post 694740)
Can you post a pic?
Whatever tomorrow brings (I bet You have the balancer, it's GM part of the engine) here what You can do:
- get an usb endoscope - remove spark plug #1 and put the camera into the cylider - bring the piston #1 to a top dead center - set the distributor so the arrow will match the marker - try cranking. If it does not start, means You're on the wrong TDC (cylinder goes twice to a TDC per cycle in 4-stroke engine). Turn the distributor 180 degrees. |
| All times are GMT -5. The time now is 07:44 PM. |
