Bizarre front window washer issue - it keeps going for days!
Old Nov 27, 2022 | 11:31 PM
Rock18's Avatar
Rock18 is on a distinguished road
Default Bizarre front window washer issue - it keeps going for days!
Had this issue for a while now and finally got fed up enough to post about it because I can't figure it out myself.
Whenever I use the windshield washer, instead of spraying and then wiping for 3-4 strokes, it goes on wiping for like 30 seconds. It gets super annoying once it starts rubbing on a dry windshield, and it wears out wiper blades unnecessarily soon.
The "quick wipe" (rotating the intermittent wiper switch collar downward briefly) does something similar, where instead of just one wipe it wants to do 5 or 6.
And weirdly, it only does this SOME OF THE TIME.
I'm suspicious that it's something in the multifunction switch stalk, but hoping someone had an idea that's cheaper/easier than taking apart the dash and steering column.
Old Nov 28, 2022 | 10:22 AM
TDS-MN's Avatar
TDS-MN is on a distinguished road
There is a common fix for this, some questionable solder joints under the hood. I had similar symptoms that were fixed by re-touching the solder joints as directed by the write-up. Access was pretty easy up by the wiper motor under the hood as I recall, it's been quite a while since I did this. I will say that eventually I did start to get some erratic operation again after a few years, but I never got around to going back in and revisiting the original fix.
Old Nov 28, 2022 | 10:40 AM
You can buy the circuit board for the wiper motor separately. It's not that expensive, and only takes a few minutes to change. I had some similar issues, and a new circuit board made it better. Not perfect, but good enough. The intermittent wipers won't work at the slowest couple of clicks, so I probably need a new MFS too. But it doesn't bother me enough to worry about it.
Old Nov 28, 2022 | 10:03 PM
puttster's Avatar
I think we bought the same switch. Cheap and easy fix. It seems like the slowest intermittents don't work but if you wait them out, they will kick in, eventually.
Old Nov 29, 2022 | 07:48 AM
Pretty funny. You're the first person I've heard of having the same problem. I'll have to try waiting for mine. I'm not very patient, lol.
Old Nov 29, 2022 | 11:52 PM
Rock18's Avatar
Oh wow, thanks! That's exactly the kind of cheap/crazy fix I was hoping for. It sounds like it could work too, because everything else on the MFS (signals, cruise, intermittent wipers) works pretty flawlessly. I'm not great with a soldering iron but that sounds like something I could manage.
Now I just have to see if I can find that reference!
Old Nov 30, 2022 | 07:28 AM
You can buy a new Dorman pulse module on Amazon for 16 bucks. What's your time worth?
Old Nov 30, 2022 | 12:58 PM
Rock18's Avatar
Even better! Ordered!
Old Nov 30, 2022 | 05:42 PM
TDS-MN's Avatar
That should fix the problem for ya. Good Luck!
Old Dec 11, 2022 | 12:24 AM
Rock18's Avatar
So I finally got around to swapping out the board and have the same problem. Everything works fine except the very slowest intermittent setting.
For $16 I can live with it though.
Thanks for the help again!
darklink
Jan 20, 2018 01:44 PM
Kemper9388
Mar 7, 2014 10:19 PM
Shaun Bogen
Dec 3, 2012 06:47 AM
degaine_designs
Feb 3, 2012 12:01 PM
Tana
Nov 10, 2008 02:00 PM
