Blazer 2000 starting "problem"
Old Apr 21, 2025 | 06:42 AM
Woffel's Avatar
Woffel is on a distinguished road
Default Blazer 2000 starting "problem"
Hello, I have newly bought a 2000 blazer with a weird too me problem. I'm not well known with these cars si I'll ask here;
When I go to turn on the vehicle, crank the engine, the car will only start if the central unlock has been pressed twice. And if I stop the engine and try too restart it, I have too unlock it twice again?
Anybody know if this is a "common" thing with a easy fix?
Old Apr 21, 2025 | 05:32 PM
I suspect there may be aftermarket equipment installed on the vehicle. Is the remote a factory GM remote? If you look under the dash, do you see a lot of wiring and/or modules just hanging out or tied up against the factory wiring loom?
Old Apr 22, 2025 | 10:52 AM
Woffel's Avatar
I will check it out once I'm in the garage again!
Old May 4, 2025 | 04:33 AM
Woffel's Avatar
Its been a while and I've checked around but can't seem too find anything hanging under the dash. There is a aftermarket chineseum radio, so I wonder if something is hooked up wrong there.
It seems like it is the original remote
Old May 4, 2025 | 12:37 PM
If it is easy to do, I'd disconnect the power to the radio and see what happens. You'll either find that the non-stock radio wiring is to blame or not. It has been many decades since a person could tap into any hot 12V wire to power a radio in a car.
Old May 11, 2025 | 01:51 PM
Woffel's Avatar
I've tried unplugging the radio but it didn't work, doesn't seem like it taped into a 12v hoy anywhere either. I also can't program a new key fob to the car, guessing it is related.
chickenhawk
Aug 25, 2013 10:05 AM
thekinz072
Jul 30, 2013 07:29 PM
lockwoodjace
Mar 24, 2013 01:11 AM
siddhartha
Jun 1, 2012 06:53 PM
Supercity
Mar 16, 2010 04:39 AM
